TwinTurbo.NET: Nissan 300ZX forum - I’m thinking you may be missing a body ground
jzack
on June 15, 2019 at 10:09 AM
Re: Did you do the basics - verify all fuses and fusible
posted by Aztecz32j
on June 14, 2019 at 08:41 AM
somewhere and excess current is going through those parts (seeking ground). causing them to heat up. On driver side rear upper plenum (top) there’s a body ground point. Wiring Harness ground needs to be well connected there...
wiring trouble!
Aztecz32j
10:35:23 06/12/19
Re: wiring trouble! UPDATE
Aztecz32j
22:19:29 06/13/19
jzack
22:40:03 06/13/19
Aztecz32j
08:41:32 06/14/19
I’m thinking you may be missing a body ground -
jzack
10:09:22 06/15/19
Z32 Grounding Question
Aztecz32j
09:41:46 06/14/19
The main battery grounds to the top of the transmission bolt (n/m)
itsa300zx
09:53:11 06/14/19
Re: The main battery grounds to the top of the transmission bolt
Aztecz32j
10:06:58 06/14/19
I just looked and it grounds to the firewall also then down
itsa300zx
10:17:54 06/14/19
No luck. Positive terminal question
Aztecz32j
21:04:45 06/14/19
Update! Pls help if you can
Aztecz32j
07:54:40 06/16/19
Re: wiring trouble update! z32 GLL = good luck loser
Aztecz32j
08:03:24 06/23/19
Aztecz32j
09:52:48 06/23/19
Re: Re: wiring trouble
mrchips
23:40:41 06/23/19
